There is a desktop with my Windows 10 64bit.
In which I am facing a bunch of boot issues. The issue began when I noticed that my machine was taking sometimes to boot. Once it seems fine. As soon as I rebooted then I saw an error, on a black screen where it had searched every drive looking for a file called GRLDR. At last, it resulted in me ‘Cant find GRLDR’.
Meanwhile, I research that there is a connection between GRLDR and Linux. At a time the same thing which confusing me that
I have never installed Linux on the computer.
I ran a Win10 repair disc to access startup repair options at the command prompt.
That resulted from me an error notification stating that the BCD file contains some invalid information. Status:0xc000000f The associated Windows boot loader entry may not be available for selection until the problem is rectified by an administrator.
I visited a Windows problem page there I can easily find the solution to this issue, But I can’t.
I tried again with bootrec.exe and fixboot which again said: element not found.
As soon as possible I tried to lay out the problem
So please appreciate me with a kind of help which can be offered easily to me.
Thanks a lot.
