I tried to create image backup files to no avail so far. I got these two errors that prevent the backup from happening: 0x80780166 and 0x80070002. I deleted old backup folders and introduced new ones to ensure I start clean. I also have 824 GB of 931 GB free. Still, the problem persists. What is the issue here, what should I do to make it work?
Hi there,
Please try and follow these steps:
- Run services.msc
- Set Windows Backup and Volume Shadow Copy to Automatic
- Reboot your PC
- Create a system image [from Control Panel\System and Security\Backup and Restore (Windows 7)]
It should work fine. I hope this helps.
