0xC1900208 – 0x4000C (Error)
Whenever i go to update my drivers, error 0xC1900208 – 0x4000C shows up and says i have an incompatible application.
I do not know what this means but have tried the usual; restarting my PC, uninstalling recently installed applications, defragging and cleaning up my PC, but nothing seems to work.
Is there a fix out there for this?
Cheers.
hello
go to control panel and uninstall all programs which are downloaded from unreliable source and then update all software and applications( many application have inbuilt option to check update)
then start windows in clean boot----open run window and type msconfig, then go too services and check Hide all microsoft services and then click Disable all, then go to startup and disable all applications and restart PC.
and then try to update driver
In compatibility related errors which will shows after upgrading windows you have three options
  1. Upgrade to the latest version of the application or software
  2. Uninstall a software or application
  3. Bypass Upgrade Adviser
Remove all installations other than the default apps and programs which is part of your installation package and re-install all drivers and applications that you need.
