how can i run an emulator on low end pc (1 gb ram)
Hi @ksabir,
Welcome to the community
Running the emulator is very easy in the PC but the installation vary depends on the software you choose. Since you have mentioned 1 GB of RAM So, I will share the information on Memuplay and how to install it. Please check this article on how to install memuplay in windows 10 PC.
# How to Install Memu with all Versions on Windows 10?
MEmu is an Android emulator that specializes in video games, thanks to which you can enjoy any of the many exclusive titles you can find for mobile phones and tablets, directly on your computer. You don’t need to adjust complicated settings and configure the controls, just install it and start playing.
I would recommend Nox Player, lightest version of Android Emulation.
