Hi! I’m looking for some basic information on Java in Hadoop as I am quite unfamiliar with such software. What do we use it for, what are pros and cons, are there online guides that can help me understand Java in Hadoop better? Thank you.
Hadoop is used for massive large data sets which you will hear called big data
Are you sure you want Hadoop? If your needs are that large, you might find object storage a better option. Someone like Wasabi is a good provider.
If want to know everything about Hadoop, try here
Check this link
I hope it helps
Hello @ReadHolmes
Here is the link that would help you
https://www.dezyre.com/article/unlock-answers-to-the-top-questions-what-is-big-data-and-what-is-hadoop/70
