My disk is about to get replaced by HP on replacement warranty. So, before giving to them I am planning to wipe the disk completely.
What is the best simple software to use for disk wipping?
Hi @CrazyFrog,
Check this article on DATA DESTRUCTION
It should be of great help
Hi @CrazyFrog,
My one and only suggestion is dban. Darik’s Boot and Nuke, also known as DBAN, is a free and open-source project hosted on SourceForge. The program is designed to securely erase a hard disk until its data is permanently removed.
To start, you have to download DBAN. You can do this on the same computer you’re going to erase or on an entirely different one. However you do it, the goal is to get the ISO file downloaded and then burned to a bootable device like a CD or flash drive.
Visit the DBAN download page (shown above) and then select the green download button.
Please refer this article for further step by step process How to Erase a Hard Drive Using DBAN
Hope this is helpful
Here is the list of top 10 software to wipe the disk completely
Thanks for the suggestion @johnniewhite. I will check and let you know
Thanks for the suggestion @tjnihal. I will check and let you know
Thanks for the suggestion I will check and let you know
Remo Drive Wipe is an imposing application which is used for removing the data you no longer required for fixed or removable storage devices. Removing the files from your PC does not mean that they are removed completely. In order to ensure that they are completely removed this application is the solution which can perform advanced removal methods so that the removed data can not be recovered again.
check this link there are some ways for wiping
Hi @tjnihal, Using rufus I made the bootable USB for dban. When I tried to run dban in the BIOS I am getting the following error:
cat: can't open '/proc/cmdline': No such file or directory
Do you have any idea?
Hi @CrazyFrog,
So many has mentioned the same issue with that version. Please try the lower version, you can download the version 2.2.8 version this link dban-2.2.8 this won’t give you the above error.
Hi , I Suggest you to use dban as i have already used it many times .
dban version 2.2.8 is working best for me .
Try this.
Thanks @tjnihal, this version worked like a charm. I am all set to replace the disk.
Check the options in this link
Looking to sell an old computer and want to wipe the hard drive clean before you sell it? Whatever your reason may be, there are lots of programs out there [...]
It is the real permanent data removal process and it’s impossible to retrieve data from a wiped disk. Data wiping aims to completely destroy all data from the hard drive or other storage devices.
10 best Hard Drive/Disk Data Wipe/Erase Software for Windows 10/8/7/Vista/XP
#1 MiniTool Partition Wizard
#2 DBAN
#3 Disk Wipe
#4 KillDisk
#5 CCleaner
#6 PCDiskEraser
#7 CBL Data Shredder
#8 Eraser
#9 Super File Shredder
#10 WipeDisk
You can open Windows Disk Manager by pressing Windows and R keys on the keyboard at the same time, and then input diskmgmt.msc. In the Disk Manager window, right-click the disk you’d like to wipe clean and click Format. You can also use Windows Diskpart tool to clean all data on selected hard drive.
