So, I have a problem with getting one of my clients into public folders I created. The following error occurs every single time the user tries to get in: “ Your Server Administrator has limited the number of items you can open simultaneously. Try closing messages you have opened or removing attachments and images from unsent messages you are composing .” So, I turned Cache Exchange mode and set up Download Shared Folders settings as well. However, I cannot make a registry change and other options did not suffice:
Cached/No registry change: getting the error
Cached/ registry change: unusable, user would not get past splash screen
Uncached/registry change: error on server administrator
Uncached,/no registry change: error on server administrator
What are my options right now?
