I’m using several sites in one database, which means it’s not a multi-site. As I’m thinking to delete one of them and I thought of deleting tables in the database itself. Am I able to do it without having an impact on the other sites?
Check this link for more information and hopefully the solution
As long it’s not multisite, you can perform that and as long you only delete the specific table.
