Can I run Hyper-V and VMware at the same time? I have Win 10 OS and saw several people doing it on Win 8… I do not wish to create major glitches on my computer, so thought to ask you guys about it? Are there any “side effects” and will my OS allow it?
Hi @Jacob,
You cannot I am not sure where you saw it. You will get compatibility issue. You can run one at a time but that also required a work around this is the simple suggestion I got it google check thisHow to allow Hyper-V and VMware Workstation to co-exist on the same machine without an uninstall
Hope this helps
VMware is a hardware installation at the core and both can’t coexist.
Hyper V will mouont VMware guests and migrate them. Is this what you mean?
If you can add more info, I shoudl be able to quickly resolve.
