Cannot reset my Network Adapter
I have set several custom tasks on my Win 10 PC as to reset my Network Adapter at 12am, each day. They were not running as they should, often starting an hour earlier or later than scheduled. My investigation pinpoints Daylight Savings Time as a culprit but I am not sure. What are the potential causes of this and how do I fix them? Using Windows 10 Version 1909 (OS Build 18363.535).
Hi @Hopkins,
Can you please share the Task Scheduler error message for the task? Task scheduler generated failure report this will be helpful to us find the exact causes of this issue.
How do I fix network adapter problems?
If you can’t connect to a network, there might be a problem with your network adapter. You can try using the Network Adapter troubleshooter to automatically find and fix some common problems.
Open the Network Adapter troubleshooter by clicking the Start button , and then clicking Control Panel. In the search box, type troubleshooter, and then click Troubleshooting. Click View all, and then click Network Adapter.
Here are some common reasons for network adapter problems, and related solutions:
The network adapter is disabled.
To enable the adapter:
Open Network Connections by clicking the Start button , and then clicking Control Panel. In the search box, type adapter, and then, under Network and Sharing Center, click View network connections.
Right-click the network adapter icon, and then click Enable. If you’re prompted for an administrator password or confirmation, type the password or provide confirmation.
The network adapter needs to be reset.
To reset the adapter:
Right-click the network adapter icon, and then click Disable. If you’re prompted for an administrator password or confirmation, type the password or provide confirmation.
Right-click the adapter icon again, and then click Enable. If you’re prompted for an administrator password or confirmation, type the password or provide confirmation.
The adapter is now reset. Try connecting to the network again, or run the Network troubleshooter to verify that your network adapter is now working correctly.
Open the Network troubleshooter by right-clicking the network icon in the notification area, and then clicking Troubleshoot problems.
The network adapter driver is missing, isn’t working, or is out of date.
You must be logged on as an administrator to perform these steps.
If you reset your network adapter and you still can’t connect to a network, you might need to update the adapter driver. (Updating the driver can solve the problem of missing or failed drivers, as well as outdated ones.) To update your network adapter driver, follow these steps:
Open Device Manager by clicking the Start button , clicking Control Panel, clicking System and Security, and then, under System, clicking Device Manager.? If you’re prompted for an administrator password or confirmation, type the password or provide confirmation.
Double-click Network Adapters, right-click your adapter, and then click Properties.
Click the Driver tab, and then click Update Driver.
If Windows can’t find the driver on your computer and you don’t have a connection to the Internet, you might need to contact the network adapter manufacturer or your computer manufacturer to get the driver. Check the information that came with your network adapter or your computer to see if you have a disc that contains the drivers.
Once you’ve updated the driver, try connecting to the network again, or run the Network troubleshooter to verify that the adapter is updated.
The network adapter needs to be replaced.
If you’ve tried resetting the network adapter and updating the drivers, and the Network troubleshooter indicates that there’s still a problem with your network adapter, try replacing the adapter. Buy a new network adapter and install it in your computer by following the manufacturer’s instructions, or have a service technician replace the adapter for you.
