Can't use Wi-Fi and sound drivers
I’ve 64bit Win10 laptop, and after I wiped it clean, because I wanted to start from the scratch, I can’t use Wi-Fi and sound drivers, and I’m not able to find them on the laptop. Is there a way to find them or reload them from the backup? Should I do it or there is some other way?
Hello @SamuelJZ
You can check it in device manager, as mentioned by you, that it seems that after windows 10 installation, sound card driver and Wi-Fi driver not installed, if you have internet connection with your LAN (Network)Card then you can download driver or update driver using Driver pack solution
here is the link of DPS or you can download from laptop’s company vender’s website
https://drp.su/en
Hi @SamuelJZ
After the New windows 10 installation sometimes you have to install the WiFi and sound drivers.
  1. Connect your laptop with a LAN internet connection.
  2. Try to install these drivers via Driver Manager.
  3. If it not working : Driver Booster 10 Free: Official Free Driver Updater Tool for Windows 2023
    download the driver booster and install. it will automatically scan your hardware and install the mission drivers.
Hi @SamuelJZ,
Windows 10 automatically download all the required driver through interested. You just need to give internet access to the device. Go to the device manager and select the WiFi adapter choose the option to Install the driver online.
If the device is not the custom made then I would refer to the manufacturer site to download the appropriate software for WiFi and sound card
windows 10 automatically download drivers. you need to connect LAN cable. also you can go to device manager and if your driver is not installed, right click on it and Update driver automatically.
OR you can use DriverPAck to downlaod and install your drivers
Top 2 Solutions to Fix Windows 10 Wi-Fi Not Available Issue
  • Top 1. Enter Command to Fix No Wi-Fi after Windows 10 Update; you can use command to fix this Windows 10 no Wi-Fi problem if it’s triggered by VPN software.
  • Top 2. Update Wi-Fi Adapter Drivers on Windows 10
If you still fail to fix the Windows 10 no Wi-Fi available or no wireless connection problem with the methods above, you can factory reset your laptop or desktop.
First, download latest drivers for audio and wifi adapter.
Wifi:
Now, go to device manager, open “Network Adapters” folder
right click wifi adapter
choose uninstall & check “delete the software for this device”, enter
right click “Network Adapters” folder
choose “scan for hardware changes”
when another wifi adapter appears, restart pc
go to settings-network & internet-wifi
if wifi connection that you are looking for is not there, turn wifi off for about 1 min
then turn back on
or if chosen connection appears, click & check connect.
open edge and access internet
If still not connecting, go back to device manager-wifi adapter & right click choose update driver software online
Notice, you may not need to use latest downloaded wifi driver.
