On one of my sites, I commenced a full O365 migration. SO far, many of the mailboxes were moved successfully and without any issues. Trouble started with one batch, where I got Azure AD failure when migration was complete (or incomplete if you will). This is the error message I am getting right now:
“Warning: The following failure occurred after the Active Directory modification completed: The domain controller ‘SN1PR16A001DC06.NAMPR16A001.PROD.OUTLOOK.COM’ is not available for use at the moment. Please try again.”
What might be the cause for this, especially if other batches were ok?
Here are the steps to investigate and resolve the issue:
1. Check Domain Controller Availability:
Verify connectivity: Use tools like Ping and NSLookup to confirm that you can reach the domain controller SN1PR16A001DC06.NAMPR16A001.PROD.OUTLOOK.COM from your migration server.
Check status: If you have access to Azure AD Connect, review the synchronization status to see if any errors or warnings are reported for that domain controller.
Contact Microsoft support: If the domain controller is unavailable, contact Microsoft support for further guidance.
2. Retry the Migration:
Review migration logs: Examine the logs for specific error details beyond the general warning message.
Attempt resubmission: Sometimes, transient errors can be resolved by simply retrying the failed batch.
3. Isolate User Accounts:
If resubmission fails, isolate a few mailboxes from the problematic batch and try migrating them individually to pinpoint specific account issues.
4. Review Migration Tool Configuration:
Settings verification: Double-check the configuration of your migration tool, including any authentication settings or specific domain controller preferences.
Update software: Ensure you’re using the latest migration tool version, as updates often address known issues.
5. Address Network Connectivity Issues:
Firewall rules: Verify that necessary firewall rules allow communication between your migration server and the Azure AD domain controller.
Network stability: Check for any network outages or latency issues that might be hindering communication.
6. Consider Microsoft Support:
If the issue persists after these steps, engage Microsoft support for further troubleshooting and assistance. They can provide deeper insights into Azure AD health and configuration.
