Corrupted start menu
Hello everyone. Can anyone help me with corrupted start menu? Many of my apps do not appear on the list when I open up a start menu. I can only run them through the store and I already tried doing many things to fix this (reset store, run Get-AppxPackage –AllUsers, shell:AppsFolder, and system reboot). Did anyone had this particular issues and how did you solve it?
You can try this
  1. go to registry editor (type regedit in run window)
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ ImmersiveShell\Launcher
  2. click edit and and create new DWORD(32-bit) value and name it UseExperience
  3. double-click on value and set the value to 1 and then OK
and then restart your PC
Hi @13999,
First try to login with another user in the same PC which if the start menu is normal then the problem lies in user profile So, you need to delete the user profile in effected PC and try to recreate again I see most of the time user profile get cached data get corrupted.
Follow this article for guidance How To Delete User Profile in Windows 10
Hi there,
I request you to try booting to Safe Mode and immediately booting back to normal mode.
Follow the steps to enter Safe mode:
  1. Open the Settings menu and go to Update & security > Recovery > Advanced startup. Clicking Advanced startup will restart your PC in recovery mode.
  2. Click Troubleshoot to see your advanced options.
  3. In the Troubleshoot menu, click Advanced options . Click Startup Settings to change Windows’ startup behavior.
  4. In the Startup Settings menu, click the Restart button to restart your PC. Your PC will now restart.
  5. To start up in Safe Mode with networking, press 5 or F5 .
You can first try sign in using a different account if problem persists try to clean install or recover OS as possible.
