Hi all. By a mistake, I accidently deleted a wrong NTFS partition and then created a new ext4-partition on HD. How can I “undo” this action or is old data already doomed?
It really depends on how much damage the ext4 format did to begin with. If all ext4 does is write a superblock, then your data is probably all there. Problem is there’s no entry point into the NTFS format cmd that I know of that says “just write superblock info and don’t touch anything else”. So what you have to do is cheat.
- create a DD image of your hard disk and save it somewhere safe. You’ll probably need a extra disk to do this because of the sheer space being used.
- format the disk as NTFS
- compare the two disks at the block level, the image you made vs the actual disk using the
cmp
utility.
Please follow the link below
When using a computer to cope with some things in work and life, partition loss is a common situation and all partition data is also deleted. But don’t worry. Today in this post, we will show you how to easily recover deleted NTFS partition, as well as the partition data with the best NTFS partition recovery software, MiniTool Partition Wizard
