use HDD re generator software for bad-sectors repair.
i have using this software for more than 1 year. every time it help me to repair bad-sectors in my disk.
try this it will help you.
Hi @tjnihal, Thanks for the reply. I run the diagnostic teat both the Quick and Extensive. Quick test get passed but extensive ended up in error please check the below error. I don’t no what long dst means.
@CrazyFrog, This means you hard disk on the edge of failure and going to fail very soon. I suggest you to take the backup or Image of the disk immediately and replace with new disk. If you have a active warranty then you may contact the HP support with the above image they will replace the disk under warranty.
Today I contacted the HP support by sharing the HP hard drive diagnostic report they agreed to replace the disk within 48 hours. Finally now I can breathing.
Thanks all for your help.
Above are the great suggestions by other fellow members. If the Long DST has failed, then probably the disk is failing. You can confirm that by following the below process:
Run a CHKDSK scan to scan the hard drive for bad sectors and mark them as bad.
Use a third-party hard drive diagnostic tool to test the hard drive for errors.
Replace the bad sector with a spare sector.
Replace the hard drive altogether.
The frequency of the error messages. If you are getting the error messages frequently, then it is more likely that the hard drive is failing and needs to be replaced.
The age of the hard drive. Older hard drives are more likely to develop bad sectors.
The type of data that is stored on the hard drive. If the hard drive contains important data, it is important to back it up before running any repairs.
If you are unsure how to resolve the issue, you can let us know in the comment section below.
