DMARC recodrd in DNS error
I have a sending email error. The problem lies in DMARC record in DNS, with record being:
v=DMARC1; p=none; rua=mailto:Demarc@onmicrosoft.com; ruf=mailto:Demarc_forensic@onmicrosoft.com; fo=1:d:s.
So, what am I doing wrong here?!
I found similar user solution on Microsoft forum that the problem was period(dot) at the end of the record, after removing period and DNS repopulated, everything seems working properly.
If you are encountering this error of No DMARC Record found, this means that your domain does not have a published DMARC record . DMARC Records are published via DNS as a text(TXT) record . They will let receiving servers know what they should do with non-aligned email received from your domain.
