Hi all. I have an issue with Drive D reparation, whereas Windows is stuck at 9%. Win 10 OS and it has been stuck on that percentage for an hour now (Scanning and Repairing Drive D: 9% Complete). What should I do?
Try to check and repair with CMD
open CMD with administrator and type D:\chkdsk /f /r
Hi @Vinnie
It may happen because of bad sectors on the disk
based on that problem it may take more hours to solve the issue
or Just turn off the PC and restart.
but anyhow you to have to do the manual disk error checking when load windows.
Check your disk for possible errors using chekdisk utility, consider replacing your faulty drives.
