Dual boot issue - Win 10 and Linux Mint 17.2
Hi, dual boot issue here! I am using Windows 10 and Linux Mint 17.2 and having issues on unresponsive mouse and keyboard upon login. They are frozen for a minute and then starts to be responsive. I tried to find online help but did not get any useful tips. Can you guys help me out? This is how error reads when I boot from Windows and go to Linux:
usb 3-10: device descriptor read/64, error -71
usb 3-10: device not accepting address 6, error -71
usb 3-10: device not accepting address 7, error -71
usb usb3-port10: unable to enumerate USB device
hid-generic 0003:1B1C:1B17.0002:usb_submit_urb(ctrl) failed: -1
hid-generic 0003:1B1C:1B12.0006:usb_submit_urb(ctrl) failed: -1
hid-generic 0003:1B1C:1B17.0004:usb_submit_urb(ctrl) failed: -1
I think restore in recovery mode, and selected the root prompt option might solve the errors, once at the prompt, ran the following command:
Code:
fsck /dev/sdb3
if /dev/sda6 is the partition you are having problems with, make sure the drive is connected and start in recovery mode, select the root prompt option and run the following command:
Code:
fsck /dev/sda6
restarted in recovery mode, and selected the root prompt option, once at the prompt run the following command:
  1. fsck /dev/sdb3
    (Change your partition that you have the problem)
    Eg: fsck /dev/sdb1 or fsck /dev/sdb4
Please follow the link below
At first a bit of background information: Since 1998 I used PC’s with Windows (98, ME, XP, 7, 8, 10)
https://forums.linuxmint.com/viewtopic.php?t=202883
