After my installation and upgrade of Windows 10, I was presented with this error:
“Error 0xC1900101”
Going through other forums, i have found that it is in fact a driver error. After uninstalling and reinstalling my drivers, and even downgrading again, i have not found a solution.
Can somebody help me?
run cmd with administrator and type
sc config wuauserv start=auto
sc config bits start=auto
sc config cryptsvc start=auto
sc config trustedinstaller start=auto
exit
and restart PC
Windows Update error 0xC1900101
This error is usually caused due to a device driver issue. If you face this issue, here are a few things you could try. You may need administrator permissions on your device to be able to execute some of these tasks.
- Make sure that your device has enough space
- Run Windows Update a few times
- Run Windows Update Troubleshooter
- Run Microsoft’s online troubleshooter
- Unplug extra or additional hardware
- Update third-party drivers
- Check Device Manager for errors
- Disable third-party security software
- Repair hard-drive errors
- Restore and repair Windows Update files
- Perform a Clean Boot to install Windows Updates.
