Error Code: 080070520
As a PC beginner, mistakes happen quite naturally to me. Just finished a new rig without issues and thought to myself – you did it right this time! However, when I started transferring some files from an old computer, I got a Troubleshooter message with an option to run it. I clicked it and got this as a message: “We’re sorry but we were unable to fix the problem. Error Code: 080070520.” I have no idea what might be causing it so I am turning to this forum for guidance. Thanks in advance! I might need step-by-step help as I am no computer expert.
Hi @HopkinsSway,
Transferring may have corrupted some files or missed to transfer. I suggest you should run below commands in CMD:
sfc /scannow
dism /online /cleanup-image /restorehealth
Try the Method as @tjnihal said
You need to Run SFC Command, here are the methods to Run it
SFC /SCANNOW Command at Boot
To Run SFC /SCANFILE Command at Boot
To Run SFC /SCANNOW Command in Windows 10
To Run SFC /SCANFILE Command in Windows 10
To View Only the “SFC” Scan Results from the CBS.LOG
Can be more sure about the error if can have screenshot.
You may try this:
Run sfc/scannow. Run SFC Command in Windows 10
How to fix error code 0x80070520 on Windows 10?
Scroll down and use Power Shell command as indicated above.
