Howdy! I cannot access my laptop at the moment and I am not sure what caused it all of a sudden. I get this error all the time Error code OxC0000142 and nothing works for me. I could use some immediate help as I’ve got work to do! Thanks in advance!
There are several reasons which can cause this error in your computer. One of these is a corrupted or missing system file. You may run the System File Checker to identify and troubleshoot this error.
You can also follow the steps through Fix Windows Update errors by using the DISM or System Update Readiness tool to check for any update errors.
You can also go to Event Viewer and check if there are any crash errors logged for any application.Uninstall the application and check if the error occurs again.
Hi @Archer ,
Where did you get the error exactly? I mean does it popup all of sudden in the middle of windows? or while opening certain applications? If this appears again please share a screenshot with us so that we can assist you properly. Otherwise, follow the System File Checker article Tech has mentioned above if its something related to window SFC will resolve it…
Try to boot windows in safe mode and uninstall application after that you are getting this error
Method 1
- Search System configuration and open it
- Click services
- (enable) Hide all Microsoft services
- Click disable all
- apply then ok
- Click Restart
Method 2
- Open CMD as Administrator
- Type sfc /scannow
Method 3
- Open RUN
- type regedit.exe
- HKEY_LOCAL_MACHINE >> software >> Microsoft >> Windows NT >> Current version >> Windows
- in the right panel Double click LoadApplnit_DLLs
- Change the Value 1 to 0
- Press ok and restart
Please try this-
Press Windows key + X
Click Task Manager
Select the Processes tab
Scroll down to Windows Explorer then select it
Click Restart
If that does not work:
uninstall your display driver:
Click Device Manager
Expand Display adapters
Right click the current display adapter
Click Uninstall
Exit Device Manager
Restart
Open Notepad.
Copy the following text into Notepad:
@echo off
taskkill /f /im explorer.exe
taskkill /f /im shellexperiencehost.exe
timeout /t 3 /NOBREAK > nul
del %localappdata%\Packages\Microsoft.Windows.ShellExperienceHost_cw5n1h2txyewy\TempState* /q
timeout /t 2 /NOBREAK > nul
start explorer
@echo on
Click File and Save.
Choose a location to save the file. Enter a “File name” of ClearTileCache.bat and select “Save as type” of All files (.). Click Save.
Open File Explorer and navigate to the location that you chose to save the file to. Double-click ClearTileCache.bat to run the file.
Press Windows key + R
Type: appwiz.cpl
Hit Enter
croll down to Microsoft Office
Select it
Click Change
Now, wait while the repair wizard starts up.
Choose the type of repair you would like to perform. Depending on the severity or availability of your Internet connection, you could try the first option, Quick Repair, which is much faster and tries to fix the problem without a data connection.
If that doesn’t resolve the problem, then go back and try the Online Repair option. For my particular issue, I ultimately had to use the Online Repair.
The repair process is straight-forward following the wizard. Note that you’ll need to save your work and close all Office programs first, and then click Repair.
Then wait while the repair process runs.
You will notice the repair experience is similar to a fresh installation. The amount of time it takes will depend on your connection speed and what the issue is.
You will see your Office apps light up in their respective colors while the repair completes.
Once the installation is complete, restart your computer just to be sure and launch your apps and verify if the problem you were having is resolved.
