I have come across a fault that reads:
“Error 0x8007042B 0x4000D”
After closing all tabs on my browser, force quitting unresponsive applications and cleaning up my PC, nothing seems to work.
Thanks.
Hi @JohnEdwards21,
What version of windows are you using? I think you are using older version of windows 10 which is out of support like below version 1709. Try to upgrade your PC to the latest version of windows 10 like something 1809 or 1903 it will automatically resolve this issue.
The 0x8007042B error usually pops up when the system is crashed due to the damage or corrupted files
so you have to repair your windows or make a new update
Try installing latest updates to your OS from Microsoft to fix the problem.
