I started getting a crash entry in Reliability History since yesterday when I log in, on two separate PCs. No changes were made and it isn’t affecting anything. Version 1909 Build, 535 Home Anyone else having the same issue?
If you want to clear all the failure applications on the Reliability Monitor, go to the “Run” command and type in eventvwr.msc When it opens go to the left pane and click Windows Logs. Open windows logs and underneath you will see Applications. Click on Applications. Wait till it finishes loading. Now go to the right pane and you will see “clear”. Click on that and a menu will pop up and click on “Click and Save”. Now all your errors are cleared from the Reliability Monitor and all your updates still show. Let me know how it works out. This won’t solve the problems you’re having, but it will make the Reliability Monitor look good.
