I have a VM ware machine on the Azure portal. it is windows 10 1809 and I want to install GNS3 on the virtual machine
I installed GNS3 and VMware workstation. GNS3 needs to run the GNS3 VM file in the WMware workstation or Virtual box. but when I am trying to run the VM file I am getting an error.
If you have any experience in this sphere, I need advice about how to fix this error and run GNS3 VM
thank you
