Having issues with SCREENReader
I am having issues with SCREENReader. It is quite annoying and I want to disable it. It’s set to default, and this ver of Windows has its own window sound scheme. Can anyone tell me how can I get rid of this for good and remove all of it?
Please try this-
There are three ways to turn Narrator on or off:
  • In Windows 10, press Windows logo key + Ctrl + Enter on your keyboard. In earlier versions of Windows, you may need to press Windows logo key + Enter .
  • On the sign-in screen, select the Ease of access button in the lower-right corner, and turn on the toggle under Narrator .
  • Go to Settings > Ease of Access > Narrator , and then turn on the toggle under Use Narrator .
