I just changed from the homepage to a static page but when I try to load a header it won’t display. I would be grateful if somebody is able to give me any advice on this matter. I’m using the Boston Pro theme by the way. Thank you in advance.
You’re using a commercial theme, so please use their official support channel. We feel they are best equipped to support their products.
Hey there! This is right
