. Is it possible to change Hiper-V console resolution? I am getting high DPI display, which makes the text in the console too small to be readable. This occurs in Linux without GUI and Windows PE as well. Can I somehow scale resolution to be larger?
1- Open Terminal
2- Type: sudo vi /etc/default/grub
3- Find the line starting with GRUB_CMDLINE_LINUX_DEFAULT , and add video=hyperv_fb:[the resolution you want]. The resolution I want is 1280x720. So my line ends up looking like this: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash video=hyperv_fb:1280x720"
4- Write the changes and quit vi.
5- Run: sudo update-grub
6- Reboot the virtual machine
