How to change back audio settings?
A few days ago, I ran an audio troubleshooter and I changed the audio output to headphones from speakers, and it does not work. Also, I can not change it back now and I don’t know why. Can someone tell me how can I reset the sound settings in Windows 10?
Hi @EllisB,
Welcome to the community., :bouquet:
You just need to uninstall the audio driver in the device manager or in the control panel (if you have installed a certain audio driver software) after restart your device. Upon the next start, windows will automatically detect the right audio driver for your device.
I suggest this will be the best option for your scenario.
You need to re-install your audio drivers and try changing the properties using sound settings.
Hello @EllisB
In my opinion i think that, if you are able to listen the sound in any device than you don’t need to reinstall the driver you can change sound setting as suggested by @umer
2nd option is to reinstall driver.
