How To Fix HP Laptop Stuck On Loading Screen Issue
If you have been experiencing boot failures resulting in your HP laptop being stuck on the loading screen, then it might warrant trying to get it fixed as soon as possible. Generally, these kinds of errors can happen due to hard drive corruption, boot glitches or the like.
How to fix an HP laptop stuck on the loading screen? This article will deal with ways to fix the problem without much trouble quickly.
Why is my laptop stuck at the loading screen?
If your HP laptop is stuck at the HP loading screen, then the following reasons could be the cause:
  • Your laptop’s RAM might somehow have gotten loose
  • Hard Drive corruption
  • Your Windows installation might be infected with a virus.
  • CMOS battery might not be working
Read further below to know how to fix the hp laptop stuck on the loading screen issue!
How do I stop the spinning circle on my HP laptop?
There are a few methods you may try to fix the “HP laptop stuck on loading screen” issue, such as:
  1. Disconnect external devices
If you have devices plugged into your laptop, such as a keyboard, USB dongle or the like, disconnect them, turn off your Laptop by holding the power button for a few seconds or more, and then turn it on again. This might be more than enough to fix the HP laptop stuck on the loading screen issue.
If this doesn’t work, keep reading.
  1. Do a System Restore
You may try system restore to fix the HP laptop stuck on loading screen issue. To do so, do the following steps:
  1. Turn off your laptop by pressing and holding the power button for several seconds
  2. Turn the laptop on again while quickly pressing the F11 key repeatedly
  3. In the new menu, select Troubleshoot > Advanced Options and finally, choose the System Restore option
  4. Follow the instructions and select the restore point from when your laptop was working fine.
System restore can essentially restore your computer back to a point where it was working perfectly before any sort of corruption cause it to encounter an error or face the “HP laptop stuck on loading screen” issue.
3. Restore BIOS to Default Settings
This can be one of the most effective ways of fixing the HP laptop stuck in loading screen issue. To do this, follow the instructions:
  1. Turn off your laptop by holding the power button for at least 15 seconds or more
  2. Turn it on again while repeatedly pressing the F10 key
  3. In the BIOS Setup Utility menu, choose File and tap enter on the Restore Defaults, simply tap on Yes thereafter.
Resetting the BIOS can help in fixing any corruption in the BIOS that may have happened due to an update of the BIOS or caused by system corruption.
4. Hard Reset
While this may seem like a rather simple method, you may simply try holding the power button for 30 seconds to do a hard reset. Before doing this, unplug any power adapter, USB devices or external keyboard/mouse attached to it. Also remove the battery if it is removable. By holding the power button for 30 seconds, all the power from the capacitors will be drained out.
After this, reattach the battery and try turning on the laptop again. This might have just fixed the HP laptop stuck on the loading screen issue!
5. Reseat the Hard Drive or RAM, Change the CMOS Battery
This method can be hard if you are not the type to open up your laptop. Sometimes, the error might be due to the Hard Drive or RAM becoming loose, in which case, you will have to open up your laptop manually by using a screw driver and try to attach them tightly.
You may also try getting a new CMOS battery and replace it with the old one in your laptop as that could be the very culprit for why you are encountering the HP laptop stuck on loading screen issue.
Why is my HP laptop stuck on loading screen? If you are unable to fix this problem by yourself, you may have to take your HP laptop to the HP repair center or get it fixed by a local techician. However, remember to find a good one as a scammer can easily replace your laptop parts with cheap scrap parts that may last for a few days or a month only.
Hi @tjnihal,
Thanks for sharing these fixes. 4 the option helped me fix the HP laptop stuck on loading screen. :slightly_smiling_face:
A clean installation of Windows can help you fix the loading screen problem.
Loading Secreen problem may happen whe your Ram completely fill or you open lots work on laptop
