ISO does not want to run
Mounted an ISO file to install an app, much like usual. Program works and I decided to unmount the thing. Later on, I mounted the ISO file again but this time, it did not want to run at all. Using Daemont Tools Ultra, I mount ISO but my computer does not show the icon. What might be the issue?
may be your ISO file is damaged, and there is not .exe file to run. download it from official site and try then. it will be good if you upload unmounted ISO file screenshot
Hi @Jacob
Download Power iso and try to Mount with it
Hello @Jacob
You can use the Winrar program and extract the files.
When you mount ISO it make drive in computer
and when you use winrar program it extract files in specific folder given by you
You can download winrar from
Win-rar. Com
As mentioned by other community members, your copy of iso file may be damaged or is not executable.
Please consider re downloading content from source.
