I have two LG 27" 4k displays on MacBook Pro, which worked fine on Mojave, but on Catalina, the second display is not as sharp as the first one, and in Settings, the second display doesn’t have the scaling option. Can this be fixed?
Hey There @Richardson,
This Thread Has a Lot To Give You Should Check It.
Try the solution in this link
Hope it helps
