Issues with WiFi drivers
Hi all. I have issues with my WiFi drivers, as it seems I cannot find the option in the network utilitary. I have Linux Mint 19.2 Cinnamon on a laptop Acer Aspire A515-54. Testing it with Ubuntu18, with issues going on with 04 and fedora 30 live USB as well. I could not locate the WiFi card model since nothing was written as “WiFi” at this point. Is there a way to install beta drivers for WiFi at this point? I also have Network controller [0280]: Intel Corporation Device [8086:02f0] if that helps.
Please check the link below
If you can’t get email, browse the web, or stream music, chances are you’re not connected to your network and can’t get onto the internet. To fix the problem, here are some things you can try.
Show all
Things to try first
Run the Network troubleshooter followed by networking commands
Roll back the network adapter driver
Update the network adapter driver
Temporarily turn off firewalls
Temporarily turn off any antivirus or malware-prevention software
Uninstall the network adapter driver and restart
Use network reset to reinstall network devices
Help us improve networking in Windows 10
