Minimum disc requirement for three-way mirror
Hello! As in a document below you would see that it says that the minimum disc requirement for two way mirror is 2, and the three-way mirror is 3, but when I configure a three-way mirror it shows me that I need 5 discs for a three-way mirror. Could somebody please confirm for me what is the minimum requirement for two way and three-way mirror?
Hi Danny
Thanks for your posting. Please check read through this information
Minimum number of disks for Storage Spaces
I hope you find it helpful.
Hi @Danny,
The error you got it reasonable. You need 5 disk to run a 3 way mirror. In Windows Server 2012 Storage Spaces and Windows 8 Storage Spaces, a 2-way mirror requires at least 2 physical disks. However, a 3-way mirror requires at least 5 physical disks.
The reason is that a 3-way mirror uses a quorum. In order to keep running, the mirror space must keep over 50% of the disks functioning. So a 3-way mirror must have at least 5 physical disks to be able to survive the loss of up to 2 physical disks
Hello @Danny
Two-way mirror requires minimum two Hard Disk
While three way mirror requires minimum five Harddisk
A three-way mirror requires a minimum of five disks which helps ensure quorum in the event of some crack in disk communication.
In order to keep running, the mirror space must keep over 50% of the disks functioning. So a 3 -way mirror must have at least 5 physical disks to be able to survive the loss of up to 2 physical disks .
