Ntoskrnl.exe & ntkrnlmp.exe errors
Upon recent WhoCrashed inspection, I found out that ntoskrnl.exe & ntkrnlmp.exe are causing the BSOD on my PC. It occurs right after the start-up and I am not sure what is causing it – bad hardware or faulty drivers. I need help determining the cause of the crashes and how to fix it.
Use Driver Verifier it is located %WinDir%\system32\ as Verifier.exe and check all drivers if they have any issue or if they are updated
*** WARNING: Unable to verify timestamp for LEMo6022.sys
*** ERROR: Module load completed but symbols could not be loaded for LEMo6022.sys
*** WARNING: Unable to verify timestamp for pelmouse.sys
*** ERROR: Module load completed but symbols could not be loaded for pelmouse.sys
Related to Primax Electronics Mouse Suite Driver
*** WARNING: Unable to verify timestamp for mfencbdc.sys
*** ERROR: Module load completed but symbols could not be loaded for mfencbdc.sys
mfencbdc+0x2bc74
Related to Mcafee.
For Mouse driver,
Remove the Driver and install the newest copy.
Remove the driver completely:
https://answers.microsoft.com/en-us/windows/for…
You can find the newest driver links on the manufacturer’s website or here:
http://www.carrona.org/dvrref.php
For McAfee:
https://answers.microsoft.com/en-us/protect/for…
Remove it using removal tool and use Windows Defender in its place.
