Occasional lag when using Disney+
I am having lags and occasional system pausing every few seconds when using Disney+. I have a gaming PC so I am sure it is not on my side. Has anyone experienced this problem and fixed it?
You can see event viewer and check logs. it will be good if you upload logs here
a gaming PC isn’t always do its job properly sometimes.
Have you try to clean up cache on the disk?
PC gaming is not always so friendly
When you use the app keep that app only, do not force your machine to work with more apps while you are on Disneyplus
