The features that I have included in this version are listed below:
WMI objects replaced with CIM
Serial Number information
Sound Device information
Video Controller information
Email report
PowerShell
.SYNOPSIS
The purpose of this script is to create a simple inventory.
.DESCRIPTION
This is a simple script to retrieve all computer objects in Active Directory and then connect
to each one and gather basic hardware information using Cim. The information includes Manufacturer,
Model,Serial Number, CPU, RAM, Disks, Operating System, Sound Deivces and Graphics Card Controller.
.RELATED LINKS
https://www.sconstantinou.com
.NOTES
Version 1.1
Updated: 01-06-2018 - Replaced Get-WmiObject cmdlet with Get-CimInstance
- Added Serial Number Information
- Added Sound Device Information
- Added Video Controller Information
- Added option to send CSV file through email
- Added parameters to enable email function option
Release Date: 10-02-2018
Author: Stephanos Constantinou
.EXAMPLES
Get-Inventory.ps1
Find the output under C:\Scripts_Output
Get-Inventory.ps1 -Email -Recipients user1@domain.com
Find the output under C:\Scripts_Output and an email will be sent
also to user1@domain.com
Get-Inventory.ps1 -Email -Recipients user1@domain.com,user2@domain.com
Find the output under C:\Scripts+Output and an email will be sent
also to user1@domain.com and user2@domain.com
Param(
[switch]$Email = $false,
[string]$Recipients = $nulll
$Inventory = New-Object System.Collections.ArrayList
if ($Email -eq $true){
$EmailCredentials =
$host.ui.PromptForCredential("Need email credentials",
"Provide the user that will be used to send the email.",
$To = @(($Recipients) -split ',')
$Attachement = "C:\Scripts_Output\Inventory.csv"
$From = $EmailCredentials.UserName
$EmailParameters = @{
To = $To
Subject = "Inventory"
Body = "Please find attached the inventory that you have requested."
Attachments = $Attachement
UseSsl = $True
Port = "587"
SmtpServer = "smtp.office365.com"
Credential = $EmailCredentials
From = $From}
$AllComputers = Get-ADComputer -Filter * -Properties Name
$AllComputersNames = $AllComputers.Name
Foreach ($ComputerName in $AllComputersNames) {
$Connection = Test-Connection $ComputerName -Count 1 -Quiet
$ComputerInfo = New-Object System.Object
$ComputerOS = Get-ADComputer $ComputerName -Properties OperatingSystem,OperatingSystemServicePack
$ComputerInfoOperatingSystem = $ComputerOS.OperatingSystem
$ComputerInfoOperatingSystemServicePack = $ComputerOS.OperatingSystemServicePack
$ComputerInfo |
Add-Member -MemberType NoteProperty -Name "Name" -Value "$ComputerName" -Force
$ComputerInfo |
Add-Member -MemberType NoteProperty -Name "OperatingSystem" -Value $ComputerInfoOperatingSystem
$ComputerInfo |
Add-Member -MemberType NoteProperty -Name "ServicePack" -Value $ComputerInfoOperatingSystemServicePack
if ($Connection -eq "True"){
$ComputerHW = Get-CimInstance -Class Win32_ComputerSystem -ComputerName $ComputerName |
select Manufacturer,
Model,
NumberOfProcessors,
@{Expression={$_.TotalPhysicalMemory / 1GB};Label="TotalPhysicalMemoryGB"}
$ComputerCPU = Get-CimInstance win32_processor -ComputerName $ComputerName |
select DeviceID,
Name,
Manufacturer,
NumberOfCores,
NumberOfLogicalProcessors
$ComputerDisks = Get-CimInstance -Class Win32_LogicalDisk -Filter "DriveType=3" -ComputerName $ComputerName |
select DeviceID,
VolumeName,
@{Expression={$_.Size / 1GB};Label="SizeGB"}
$ComputerSerial = (Get-CimInstance Win32_Bios -ComputerName $ComputerName).SerialNumber
$ComputerGraphics = Get-CimInstance -Class Win32_VideoController |
select Name,
@{Expression={$_.AdapterRAM / 1GB};Label="GraphicsRAM"}
$ComputerSoundDevices = (Get-CimInstance -Class Win32_SoundDevice).Name
$ComputerInfoManufacturer = $ComputerHW.Manufacturer
$ComputerInfoModel = $ComputerHW.Model
$ComputerInfoNumberOfProcessors = $ComputerHW.NumberOfProcessors
$ComputerInfoProcessorID = $ComputerCPU.DeviceID
$ComputerInfoProcessorManufacturer = $ComputerCPU.Manufacturer
$ComputerInfoProcessorName = $ComputerCPU.Name
$ComputerInfoNumberOfCores = $ComputerCPU.NumberOfCores
$ComputerInfoNumberOfLogicalProcessors = $ComputerCPU.NumberOfLogicalProcessors
$ComputerInfoRAM = $ComputerHW.TotalPhysicalMemoryGB
$ComputerInfoDiskDrive = $ComputerDisks.DeviceID
$ComputerInfoDriveName = $ComputerDisks.VolumeName
$ComputerInfoSize = $ComputerDisks.SizeGB
$ComputerInfoGraphicsName = $ComputerGraphics.Name
$ComputerInfoGraphicsRAM = $ComputerGraphics.GraphicsRAM
$ComputerInfo |
Add-Member -MemberType NoteProperty -Name "Manufacturer" -Value "$ComputerInfoManufacturer" -Force
$ComputerInfo |
Add-Member -MemberType NoteProperty -Name "Model" -Value "$ComputerInfoModel" -Force
$ComputerInfo |
Add-Member -MemberType NoteProperty -Name "Serial" -Value "$ComputerSerial" -Force
$ComputerInfo |
Add-Member -MemberType NoteProperty -Name "NumberOfProcessors" -Value "$ComputerInfoNumberOfProcessors" -Force
$ComputerInfo |
Add-Member -MemberType NoteProperty -Name "ProcessorID" -Value "$ComputerInfoProcessorID" -Force
$ComputerInfo |
Add-Member -MemberType NoteProperty -Name "ProcessorManufacturer" -Value "$ComputerInfoProcessorManufacturer" -Force
$ComputerInfo |
Add-Member -MemberType NoteProperty -Name "ProcessorName" -Value "$ComputerInfoProcessorName" -Force
$ComputerInfo |
Add-Member -MemberType NoteProperty -Name "NumberOfCores" -Value "$ComputerInfoNumberOfCores" -Force
$ComputerInfo |
Add-Member -MemberType NoteProperty -Name "NumberOfLogicalProcessors" -Value "$ComputerInfoNumberOfLogicalProcessors" -Force
$ComputerInfo |
Add-Member -MemberType NoteProperty -Name "RAM" -Value "$ComputerInfoRAM" -Force
$ComputerInfo |
Add-Member -MemberType NoteProperty -Name "DiskDrive" -Value "$ComputerInfoDiskDrive" -Force
$ComputerInfo |
Add-Member -MemberType NoteProperty -Name "DriveName" -Value "$ComputerInfoDriveName" -Force
$ComputerInfo |
Add-Member -MemberType NoteProperty -Name "Size" -Value "$ComputerInfoSize"-Force
$ComputerInfo |
Add-Member -MemberType NoteProperty -Name "Graphics" -Value "$ComputerInfoGraphicsName"-Force
$ComputerInfo |
Add-Member -MemberType NoteProperty -Name "GraphicsRAM" -Value "$ComputerInfoGraphicsRAM"-Force
$ComputerInfo |
Add-Member -MemberType NoteProperty -Name "SoundDevices" -Value "$ComputerSoundDevices"-Force
$Inventory.Add($ComputerInfo) | Out-Null
$ComputerHW = ββ
$ComputerCPU = ββ
$ComputerDisks = ββ
$ComputerSerial = ββ
$ComputerGraphics = ββ
$ComputerSoundDevices = ββ
$Inventory | Export-Csv C:\Scripts_Output\Inventory.csv
if ($Email -eq $true){send-mailmessage @EmailParameters}
