Dear friends,
After upgrade from Windows 7 to Windows 10 my laptop keeps going in Sleep mode after 5 minutes. I tried to change the power plan settings, but it didn’t work. Also, I tried “change when to turn off the display>Change advanced power settings” but at the new window, the button Restore plan defaults is not available.
#I run at cmd powercfg -restore default schemes ant took the message:
The power scheme, subgroup, or setting specified does not exist.
#I run also sfc /scannow and took the message:
Windows Resource Protection found corrupt files but was unable to fix some
of them. Details are included in the CBS.Log windir\Logs\CBS\CBS.log. For
example C:\Windows\Logs\CBS\CBS.log. Note that logging is currently not
supported in offline servicing scenarios.
#I could give you the log file but is big! Perhaps you need a specific point of the file?
Any help which can fix this issue
Thanks a lot
