When I click a key on my keyboard it sometimes generates endless repeating of that click, and I have to click other keys and backspace to make it stop. Bought a new keyboard, the issue repeated after a few days. How can I find the source of this problem?
Hi Samuel
Please check Fix Repeating Keys With These Tips. It will help you identify and resolve keyboard problem.
The problem could be that you have a bug, an AV will solutionate that
Hello @Samuel
Welcome to community!
Would you please tell me which type of keyboard you are using?
Is there any specific key or all the keys of keyboard is malfunctioning.
- Go to Start, Control Panel.
- Choose Accessibility Options. …
- On the Keyboard tab, check “Filter Keys” and click “Settings” button.
- Select “Ignore Quick Keystrokes” and click “Settings” button.
- Select "No Repeat
