I have a question about Intel Rapid Storage. I don’t have a Raid setup, but I do have 2 SSD’s (one for gaming and windows and one for backups), and since I installed Intel Rapid Storage, whenever the application starts, I get a notification which says something like “something almost failed” or “driver failure”. Should I be concerned about this notification?
Please check event viewer and post here your event viewer log to see the reason of your problem
Well, to prevent fatal error in future I suggest you to back up, possibly in external HDD and format the whole disk into like a brand new one, I presumably that the disk is kinda affected by some kind of hidden malware in accordance to your notification errors.
