I am a new system admin and this is my first job. I have been tasked to delete and remap the network drive in our network. So, please advise how to Removes network drives P (10.10.10.4)and then map new network drives P (10.10.10.11) I am using the below VBS Script to achieve the task.
Please find the below script for your reference:
Option Explicit
Dim objNetwork, objShell
Dim strDriveLetter, strNetworkPath, strExplorer
strDriveLetter = "P:"
strNetworkPath = "\\10.10.10.4\data"
Set objNetwork = CreateObject("WScript.Network")
‘ Section which removes strDriveLetter
objNetwork.MapNetworkDrive strDriveLetter, strNetworkPath
Set objShell = CreateObject("WScript.Shell")
strExplorer = "Explorer" & " " & strDriveLetter
objShell.run (strExplorer)
Wscript.Quit
‘ End of Script
Dim objNetwork, strDriveLetter
strNetworkPath = "\\10.10.10.11\data"
objNetwork.RemoveNetworkDrive strDriveLetter
Wscript.Quit
Thanks for your help and much greatly appreciated.
Why are you trying to map the network drive using VBS Script. It will be very easier if you use CMD command like below to delete the existing drive and connect the new one.
This command will delete the existing drive Net use q: /del
This command will map the new drive Net use q: \\10.10.10.11\data
If you are in a domain environment I would recommend using Group Policy Preference to map the drive. Using scripts to manage drive mappings has been deprecated since Group Policy Preferences were released and also the use of VBscript is being deprecated now.
So, Group Policy is the recommended method for this use case.
I hope this helps let me know if you have any clarifications
hmm… Why do you want non team members to have access? That seems like what you would use the main Google Drive for?
As for all team members have full control - I’m guessing that goes to a general thinking that this is used by the team for the team, nothing should be here that’s not full access for all team members - right or wrong - it’s just one way of doing things.
