Several months ago, I started building up my PC. Since then, I saw several BSODs going on. Now, I need help with errors in memtest86 test 10. I ran several tests beforehand and everything worked fine (have 2 dimms installed but I installed new BIOS with 1 dimm). What might be causing the issue?
hello
go to bios setup and then Boot Options > EFI Optimized Boot > Enabled allows the Bit fade test to pass
and it may fix your problem
These crashes were related to memory corruption (probably caused by a driver).
Please run these two tests to verify your memory and find which driver is causing the problem. Please run verifier first. You do not need to run memtest yet unless verifier does not find the cause, or you want to.
If you are over-clocking anything reset to default before running these tests.
In other words STOP!!! If you do not know what this means you probably are not
1-Driver verifier
2-Memtest.
