Hi, I need a program or something similar to write notes from some lessons on Youtube, which I will be learning from for a few months. Can someone recommend something where I can write on a daily basis without having to close or move anything? It should be through Linux OS, as I am using one. Thanks!
Check this link
It has many options
Hello @Hunt
Here is the link of making note list, which is supported by Red Hat
