When I open a Google Chrome tab, I get Searchmine as my homepage even though I never changed my homepage. My homepage is Google.com and I’m not sure why this happened. Searchmine won’t be removed even after an AV scan or trying other possibilities. Help please, because it seems virus took reigns on my computer?
check the solution in this link
Hello @Davisman
Welcome to community! ![]()
Try this option to remove searchmine Searchmine.net Redirect (Mac) - Removal steps, and macOS cleanup (updated)
First go to control panel and uninstall any unknown software, then go to google chrome and in extensions disable all unknown soft also. and clear all your browsing data. then run malwarebytes and check if problem exists
