at my home, I have Huawey ONT Hg8546m. I have LAN and WIFI connection, but at second-floor wifi signal is weak, so I decided to make wifi repeater.
I have a TP-link router (TL-WR842ND TP-Link 300Mbps Multi-Function Wireless N Router).
and I installed it as repeater-this function it has on the menu.
then I connected it to Huawey wifi signal, entered password and connection established.
But here it becomes a problem.
when I connect to TP-link wifi I can’t access the Internet.
to fix this problem I changed the TP-Link wifi repeater default setting.
I have changed the DNS server to 8.8.8.8 and also changed the repeater gateway to main router IP.
It didn’t work then I returned default settings and I changed 8.8.8.8 to main router IP but nothing happened.
I saw many videos about it, but it didn’t help me
If you have any solution to it please advise me.
thank you
