Use Win 10 USB installation stick on an Android device
Hi everyone, computer beginner here!
Is it possible to use Win 10 USB installation stick on an Android device? If yes, how should I do it?
Thanks!
Hi @Lennon,
Pardon me if I am wrong, your question is not elaborated to understand properly So, I assume you are trying to install windows 10 from an Android device? Then yes, you can do it but for that, you need to have or root your Android device first. Please refer to the below article which explains clearly
# How to Install Windows 10 from an Android Phone
No, Android Device won’t be able to execute nor recognize those binary programs.
