Is someone using VC-500W? It is a ZINK colour-label printer that I am interested in purchasing. Right now, I have trouble with getting P700 to print, so VC-500W might be even more complex to set up. Did someone get it working out properly?
hello
Did you try to fix trouble with P700 ?
Hi @Luke
Try this, may be it will work to getting P700 to print,
- If the Editor Lite lamp is lit, press and hold down the Editor Lite button until the Editor Lite lamp turns off in your printer.
2.Check with driver installed for this printer & Cancel all waiting documents in print files.
Let me know if its work? else i will check for the other solutions.
Cheers
