Hi! A few hours ago, I tried to do Visual C++ updates on my PC (Win 10). Installation fails every time but when I look into the Winver, it says I already have it installed, latest update that is. What is going on?!
hi @BernV
download all in one runtime and install it : All in One Runtimes Download - ComputerBase
it will install the missing Visual c++ automatically.
Download file from here Latest supported Visual C++ Redistributable downloads | Microsoft Learn
and if you will have any error, uninstall it from control panel and reinstall again
it will fix your problem
