I am looking for a network monitoring tool for my small office. As of now we have 50 computers and a few networking devices. I talked to the management and it seems they don’t have approval for the budget so looking for any free tool.
So, far I have collected the tool and counting on:
Spicework network monitoring tool
Lansweeper
Opmanager
Any recommendation on the above or new suggestions are welcome.
We use https://www.paessler.com/ on a lot of our sites.
It needs to be hosted on a server and takes a white to set up.
If your needs are basic and you don’t want to manage a central server as well, one of the other products will work OK. GFI is also a big player who we have used when they were branded Hound Dog
You can try Nagios
Is popular due to its active development community and external plug-in support. You can create and use external plugins in the form of executable files or Perl and shell scripts to monitor and collect metrics from every hardware and software used in a network. There are plugins that provide an easier and better GUI, address many limitations in the Core, and support features, such as auto discovery, extended graphing.
When did you last check the Spiceworks networking tool? Due to a reported vulnerability, Spiceworks Network Monitor will no longer be available and supported effective January 20, 2020. So, you should not consider Spiceworks instead you may try Connectivity Dashboard it’s a similar cloud version.
Lansweeper is not a network monitoring tool. Lansweeper is an application that gathers hardware and software information of computers and other devices on a computer network for management and compliance and audit purposes
I would recommend PRTG as I have been using it for a few years. Plus It offers 100 free sensors which will enough for a small office.
