Why Won't My iPhone Backup When I Have Enough Storage
The only way to recover data to new phones or into the same phone is by creating backups and then restoring them. Data can be lost for many reasons. Mobile theft or other damages are such an example. To avoid data loss, you should create backups.
iCloud is one popular way to take backups, and if you are having trouble creating backups, then follow the troubleshooting guide below.
7 Methods To Fix Failing of Phone Backups
1] Check Service Status
The first step should be to check if the service is currently down or not from Apple’s side. To check this, just search for ‘Apple’s System Status’. After opening the webpage, you will see a list of all Apple services that are available. Find the status of the iCloud service.
2] Reset Network Settings
If you have enough storage available and the backup is still failing, then reset your network settings. This is because creating backups requires you to have internet access, and a bad setting can cause havoc. Follow these steps to reset your network settings to default.
  • Launch ‘Settings’.
  • Navigate to General → Transfer or Reset iPhone → Reset.
  • Tap on the ‘Reset Network Settings’.
Also, ensure that your Wi-Fi is connected and does not lose its strength very often.
3] Check Your Next Backup Size
You might have enough space as per your calculation, but it is a good idea to see the size of your next backup. You do not need to manually do it, as your iOS device will automatically do this.
  • Tap your name at the top of the screen.
  • Click ‘iCloud’.
  • Click ‘iCloud Backup’ and tap on the icon of your iPhone.
  • You will see the size of your next backup.
This is probably the cause that you are not able to create a backup. Try minimising the size, and the issue will be resolved.
4] Turn On/Off iCloud Backup
Restarting things can sometimes solve the issue as if they were not there in the first place. That is what we will do with iCloud. To see if the issue s because of iCloud not working properly, turn it off and turn it on. Here is how you do it.
  • Open ‘Settings’ app.
  • Click on your name that you see at the top.
  • Navigate to iCloud → iCloud Backup.
  • Toggle the ‘Back Up This iPhone’ option to turn it off and then turn it back on.
  • Now, try creating a backup.
5] Re-login into the iCloud Account
If turning off and on the backups did not solve the issue, then in the reverse engineering process, let’s re-login iCloud.
  • Open your ‘Settings’ app.
  • Click your name at the top.
  • Tap ‘Sign Out’ at the very bottom.
  • Wait for a few minutes. You can also restart your iPhone.
  • Now again, sign in to your iCloud account.
  • Try taking the backup now.
6] Update to the Latest iOS
There is no surprise that a bug in your current iOS is causing this issue. That is why Apple releases new iOS versions. Try updating your iPhone to the latest version if one is available. This is how you upgrade the software.
  • Open ‘Settings’.
  • Navigate to General → Software Update.
  • Tap on ‘Download and Install’.
Ensure that your iPhone is fully charged. If not, keep it plugged in.
7] Corrupt Existing Backup
It is possible that an existing backup has become corrupted and is causing the issue. In that case, you need to first delete it and then create a new one. To delete the backup, navigate to
Settings → Your Name → iCloud → iCloud Backup → Your iPhone Name
At the very end, you will see an option to delete the backup.
It is important to take backups to avoid data losses. If you are taking backups and they are failing, you would be thinking, why won’t my iPhone backup when I have enough storage? There could be many reasons for this issue. You can fix the issue using the methods explained above.
With the troubleshooting guide and solutions explained above, you can rectify the issue within no time. Those tips will let you know what exactly is causing the issue, even when sufficient storage space is available. Always take regular backups to avoid data losses and to be prepared for unforeseen events.
