I want to install New chromium-based Edge in my PC.
My Legacy Edge browser is very troublesome. The share and printing features completely stopped working for a longtime. So, Now I would like to remove it edge browser completely from my PC and install the new Chromium-based Edge.
I don’t want to have both browsers installed on the same PC I think it may cause some problem. Especially, when one of them is broken it may cause to other unstable (what i belive)
I could run the below PowerShell command, however, I’m not sure what the side-effects are from doing that. So, What will be the best way to have chromium-based Edge in my PC.
There are ways. However, I advise them not to uninstall. Uninstalling may cause additional problems. Let him just on the place. When you install the new Edge Chromium, the old one is invisible.
Follow the below link to download New edge for your device.
Download the new Microsoft Edge based on Chromium
Applies to: Microsoft EdgeWindows 10
The new Microsoft Edge is based on Chromium and was released on January 15, 2020. It is compatible with all supported versions of Windows, and macOS. Downloading the browser will replace the legacy version of Microsoft Edge on Windows 10 PCs. With speed, performance, best in class compatibility for websites and extensions, and built-in privacy and security features, it’s the only browser you’ll ever need.
